The two pipes side by side, one should go to the block breather already fitted, I did away with the
flame trap on my turbo yb setup.
The other one people normally fit to a fitting at the back of the cam cover, if you turn the cam
cover upside down you will see a mark where you can drill and fit it.
One of the lower ones , you can go back to the lower block with for a return, on a 200 block there
is a fitting on the rear of the rhs of the block you can use.
The other one I would fit a pipe to with a k&n breather filter above the engine.
Hope this helps.
puddy :thumbsup:
