carter-199 Posted May 14, 2012 Report Posted May 14, 2012 Got escort MOTed today so 1st time I've used it and on way home kept cutting out like ignition was being turned off. Rev counter dies as does engine. Does anybody have any ideas. I've put new plugs rotor arm dizzy cap and leads.
Savvi Posted May 14, 2012 Report Posted May 14, 2012 Check fuses and the round bulkhead plug, also battery terminals and earths for bad connection.
carter-199 Posted May 15, 2012 Author Report Posted May 15, 2012 Yeah I'll check them ordered a new coil aswell today just to be safe. I've noticed that wire that goes into middle of starter solenoid is quite loose would that be a problem?
jayremedy Posted May 16, 2012 Report Posted May 16, 2012 I bought some spark plugs from ebay advertised for a MK1 escort crossflow but they kept cutting out and would only start again when it cooled down and eventually 2 stopped working altogether. Went back to the ones I took out as they weren't really worn and had no problems since. Just a thought.
carter-199 Posted May 17, 2012 Author Report Posted May 17, 2012 Put new coil on today and still keeps cutting out and when I try start there is no spark then try again and it starts. So it keeps loosing spark and I've replaced most common things do ignitions play up.
GJUK Posted May 18, 2012 Report Posted May 18, 2012 Yes it's got electronic ignition Are you running a direct 12v feed to the possitive on the coil from your ignition?
carter-199 Posted May 18, 2012 Author Report Posted May 18, 2012 I'll have to check that out as it was fitted to the car when I bought it. So there should be 12v going to coil when ignition is on
carter-199 Posted May 18, 2012 Author Report Posted May 18, 2012 Ok mate cheers I'll have a look but it's a intermittent fault so don't do it all the time
