mk2 mike Posted December 8, 2012 Report Posted December 8, 2012 Hi guys hope you're well. Quick question for you, I need to charge the escort battery as its flat. I've taken it off the car, but do I need to remove the cell caps before charging or not?
Escort Mk1 4 Door Posted December 8, 2012 Report Posted December 8, 2012 has it got a very hole or tube on one side of the battery? is so no just bung it on if not i always crack the caps undo them and i leave them in the holes loose to stop the acid coming out if anything happens
mk2 mike Posted December 8, 2012 Author Report Posted December 8, 2012 No there's no hole or tube. I'll just open the caps slightly like you say. Cheers mate.
Escort Mk1 4 Door Posted December 8, 2012 Report Posted December 8, 2012 no worrys mate heard of batterys splitting or leaking before when not been opened
Col-ashtonmobile Posted December 9, 2012 Report Posted December 9, 2012 and switch off at the mains before disconnecting the leads
Escort Mk1 4 Door Posted December 9, 2012 Report Posted December 9, 2012 good point dont want any sparks if theres fumes or vapours comming offf battery
