My mk1 currently has a small Odyssey racing battery located under the drivers seat.
Although its very neat and tidy I'd rather have a 'proper' battery in the boot.
There are obviously loads of options but how have you done yours?
I don't want to use the spare wheel well I think it's better tucked up the back behind the back seat, although saying that, does it make it hard to access? so what's best:-
Alloy or plastic box
What size cable
Inline fuse? Etc etc :thumbsup:
Good question ........ And I can't give a particularly good answer tbh!
It was new last year and goes flat pretty quickly . My fault I suppose as I left it connected when the car wasn't used for a couple of weeks. It turns the engine over quite slow which isn't usually a problem as it will generally be on the button, but if it isn't, you haven't got much cranking time before you kill it . I think it's just one of those things I'd rather do before I get stuck in the middle of nowhere at silly o'clock. Yeah I know thats a part of osf ownership but I've never seen other road cars running a racing battery under the seat.
plastic boxs are a bit of a pain ali trays are easier to clamp the battery in, mount the battery where ever you want thats the good thing about having a remote tray use a nice heavy duty cable i think on my rs i had used welding leads from work, you can buy some heavy duty inline fuses like i have on the rally car i dont think the main live is fused on a mk1 i didnt bother but i suppose its a good idea really newer cars are fused an if i was to do it again i would fuse it
I'd fit one of the Mexico style trays in the spare wheel well, as Ford did many moons ago.
Modern cabling means that a heavy duty type doesnt have to be as thick and hard to bend as the old stuff but still carry the same power.
Fuses fit a heavy duty 100amp mega type located near the battery, you can buy a nice looking decent fuse holder to do that from a decent supplier or ebay ............ http://www.ebay.co.uk/itm/1-x-INLINE-ME ... 4aba3aa1af
The standard Mk1's have a fusable link to the main wiring loom feed, which is the small round terminal near the radiator support, which then supplies the ignition switch by the way !!!
i run the pc680 and mines left for weeks at a time and its always started when needed to, a little trick i used to do was add extra earth straps,
battery to earth
battery to engine
engine to chassis
creates a triangle and i never had issues with starting
if you fit one of those little solar chargers sat on rear parcel shelf might help as well
never knew that :thumbsup: those mega fuses is the type i have in the rally car there the only type i could find that would take my cable size
