hi mate, repair your gear lever.or get another, you are supposed to push down against spring pressure to allow the lever to clear the detent block and engage 5th. it sounds like your lever os 'down' all the time.
cheers, ian.
hi mate, repair your gear lever.or get another, you are supposed to push down against spring pressure to allow the lever to clear the detent block and engage 5th. it sounds like your lever os 'down' all the time.cheers, ian.
Thanks mate
