For Sale i have a USED Quaife 26Z 6 Speed sequential gearbox. This is based on the Sierra TYPE 9 casing. It is the Dog engagement type, with straight cut gears. It is an overdrive box so does not whine in 6th gear. Came out of a fully working car and had no issues when running. I have also had a 'Long' Gearstick machined up for it (cost me £80) as they are quite short originally so it is more like a 60g box now. The box does not come with a bellhousing or crossmember but fits standard FORD items.
This is the box:
http://quaife.co.uk/shop/products/qbe26z6od-0
I have changed the oil every time i have changed the engine oil (bit excessive i know), so its perfect and clean inside. No leaks, noises etc.
Included in the sale is a FULL Geartronics flatshift kit in perfect working condition. This includes the ECU, gear indicator, potentiometer, custom loom, manuals, software etc. This can be wired into your current ecu so you do not have to come off the power when changing gear.
The kit includes the following:
I will Add actual pictures of the gearbox and geartronics kit as soon as i get down my unit.
If you want to come and view the gearbox, it is based in windsor, Berkshire.
A courier can be sorted at cost.
Any questions please call or txt 07879 665404
Thanks
