emu Posted November 26, 2013 Report Posted November 26, 2013 Ok, assuming I decide to keep the DHLA's on the side of my pinto, then I think I'm going to need a pressure regulator. Had a quick look around and there only seems to be a couple of choices: Either the Malpassi ones, either with filter bowl or without: OR these cheaper Sytec ones: Is there any real preference, or pro's/con's to one or the other? I do have an old Adjustable EFI pressure reg in the garage, but I assume that won't wind down far enough to use??
damian1969josh Posted November 26, 2013 Report Posted November 26, 2013 i got the top one with bowl and gauge on crossflow with twin 40 s and works find ..not seen many osf with the bottom one fitted looks to modern to me for a osf
deltamal Posted November 26, 2013 Report Posted November 26, 2013 Ok, assuming I decide to keep the DHLA's on the side of my pinto, then I think I'm going to need a pressure regulator. Had a quick look around and there only seems to be a couple of choices: Either the Malpassi ones, either with filter bowl or without: OR these cheaper Sytec ones: Is there any real preference, or pro's/con's to one or the other? I do have an old Adjustable EFI pressure reg in the garage, but I assume that won't wind down far enough to use?? You have a PM!
rallyesport04 Posted November 26, 2013 Report Posted November 26, 2013 had both filterking all the way the one with the bowl has a filter in an a blank you can fit a gauge too to help aid setting the fuel pressure there are also billet ones available with anodised colours
Mgentry90 Posted November 26, 2013 Report Posted November 26, 2013 I had similar to bottom, no problems
Fiesta Steve Posted November 27, 2013 Report Posted November 27, 2013 I use the one in the top pic. I added a pressure gauge with a T piece to set up the pressure, then removed it.
emu Posted November 28, 2013 Author Report Posted November 28, 2013 The malpassi seems to be the more common choice on our cars. All sorted now. Thank you all for your responses
