hello chaps, Im still playing with cars, getting round to some more bits now, Im trying to sort out the brakes, I might run a bias box, what size cylinders do you lot run with a drum/M16 disc setup?????
If you have a servo fitted id say leave as is as I've here'd lots of people say they regret going bias, but I haven't tried one so Maybey ask the question .
Servos, I don't like them, generally they hit the bin if I am upgrading brakes. Still might use a twin port master cylinder from a servo and increase the pedal ratio, only problem with using a dual master cyl, is they are generally quite long, so I would need to operate it using a bell crank, which is loads more work to make,
