capriclive Posted June 17, 2014 Report Posted June 17, 2014 im selling a 5.olt small block 302 v8 and auto box. its currently stripped down for rebuild on an engine stand. i ran it briefly before stripping it down. bores and pistons are good comes with over £200 of new rebuild parts including full gasket set, new piston rings, new mains and crank bearings, new core plugs, oil filter, and a few other bits. comes with a set of holley alloy rocker covers, and a hurst shifter comes with holley four barrel carb and spare holley 2 barrel carb, standard exhaust manifolds, pretty much complete engine set up just needs plugs and leads comes with engine mounts to fit into 2.8 capri crossmember, and gearbox mount to fit same. all bolt to original mounts, no mods or cutting required just needs putting back together. was destined for my capri but car now sold so surplus to requirements. engine stand does not come with it £450 no offers located in liphook. call on 07788554247 as cant always get computer access
SmokeEm Posted July 12, 2014 Report Posted July 12, 2014 If you don't hear anything Tom, text me and I will get msg to owner as i believe it still available
Tom E Cropp Posted July 12, 2014 Report Posted July 12, 2014 Thanks Dave I'll give him a call tommorrow I was going to tonight but it was a bit late
