seaneylad Posted September 8, 2014 Report Posted September 8, 2014 Hello.I see alot of people who bare metal their old skool fords when re building.. Im not doing it anytime soon but may do in a few years as mines abit rough round the edges and wouldnt mind building it up again myself to a better standard What steps do people take just out of intrest when they bare metal their cars What primers etc? and how they layer and build it up for best protection, as alot spray it them selves in a lock up/garage not in spray booth or oven etc?Thanks
mk2 matt Posted September 24, 2014 Report Posted September 24, 2014 don't do it. as soon as you strip it it will rust so unless you can paint it immediately don't
The Transplanter Posted September 24, 2014 Report Posted September 24, 2014 Theres no need to bare metal unless there are problems with the original paint on the panels. Paint any bare metal or repaired sections you have with epoxy primer, straight away to seal them
seaneylad Posted September 25, 2014 Author Report Posted September 25, 2014 don't do it. as soon as you strip it it will rust so unless you can paint it immediately don't Theres no need to bare metal unless there are problems with the original paint on the panels. Paint any bare metal or repaired sections you have with epoxy primer, straight away to seal them Ah okay thats for the info If there is rust bubbling through is it best to just rub that part down, resolve that issue and then paint it up straight away with epoxy .. See alot of Retards Club posting pics of the whole car bare metalled, must take a long time so the first part you have done must start to rust with moisture by the time you finish, as most i have seen said they have done it with a grinder and wire brush add on
