seaneylad Posted February 6, 2015 Report Posted February 6, 2015 Morning,After the engine mount cups, like pic Anyone got any for me to buy or know of anyone online selling repro's?Thanks
classicwhitey Posted February 6, 2015 Report Posted February 6, 2015 do the rubber insulaters unbolt from behind? id of thought they do. if so then new insulaters can be bought at Burtons or most motor factors.
seaneylad Posted February 6, 2015 Author Report Posted February 6, 2015 do the rubber insulaters unbolt from behind? id of thought they do. if so then new insulaters can be bought at Burtons or most motor factors. Cheers my rubbers dont last long due to having no cup to support them, so need to get the cup to support the mounts and hopefully stop the enigne moving so much
classicwhitey Posted February 6, 2015 Report Posted February 6, 2015 make your own cups, just need some tube the same size as the rubber, weld on a plate then you got it. alternativly bend some steel strip around a mount to form the cup then weld that up
nik_plant Posted February 15, 2015 Report Posted February 15, 2015 Look on retroford.co.uk he sells some stainless cups for 50mm rubbers looks smart and work well, that's what I've used
