jimrobson Posted November 24, 2015 Report Posted November 24, 2015 Time to let this go as I've got far too many cars now I had planned to use this for a bit of fun at dwyb and track days whilst making it road legal so it could drive there and back basically. Body work wise it's fairly rough but it's still got a few years use in it yet just don't expect a pretty car at this money with this spec. It also needs the logbook applying for as the previous owner never gave me it £2500 Ono no swaps just cash first come first served as space is tight currently 1975 mk2 escort 4 door 1300 base auto a very rare spec however it's changed a lot since it left ford lol 2lt pinto with big wing steel sump Rebuilt 38dgas done by Karl frost with manual choke conversion 4 branch Ashley manifold and system which are fairly new Electronic ignition with Bosch distributor Has a brand new luk clutch fitted New clutch cable 1600 xflow engine mounts 5 speed type 9 box Rs2000 front struts with 2inch lowering springs 2.8 capri vented calipers Non servo master cylinder 2.4 quick rack Group 4 steering joint Auto tunnel as standard Rs2000 prop 3.89 rear diff Single leaf rear springs with 2 inch lowering blocks Blue gl seats and door cards just needs the door cards fitting as I haven't had time rest is missing Good dash top with only a couple of minor imperfections 1 key lockset Comps pictured on the car can be included if the full asking price is met otherwise it goes on standard steels with knackered tyres Now as you can imagine there are some bad bits this is a cheap mk2 escort and as such needs work it needs: Bit of welding to the inner sills very minimal though Bit of welding around the front screen but I will try and get this sorted before it is sold Rear brakes doing and then all the brakes bleeding up etc Odds and Sod's generally wiring taping up, get the lights working etc it's not a weekends work but not miles off being on the road
HotRodMatt Posted November 25, 2015 Report Posted November 25, 2015 Uploading pictures may help you sell. [emoji106]
