katana Posted June 15, 2016 Report Posted June 15, 2016 It will certainly help if breathing was restricted beforehand.
Mike65 Posted July 10, 2016 Author Report Posted July 10, 2016 Have you got the blacktop Zetec? If so the PCV is at the back of the block (assuming you have it on a rear wheel drive car and not sideways) on the right side. Look down below the headers at the rear side of the block and you'll see a pipe coming out of the PCV which is simply pushed into a rubber grommet - you can just pull it out. Unless the valve is being operated by a vacuum source, which your setup isn't doing, then you risk the same problem I had,
mk2 mike Posted July 10, 2016 Report Posted July 10, 2016 I found my valve. Gutted it as shown. Engine still pumps oil from the rocker cover, front and rear seals. Sent from my iPhone using Tapatalk
katana Posted July 10, 2016 Report Posted July 10, 2016 Mk2M - what breathers have you got and how arranged? If its still forcing oil out of seals and the breathers, you've got serious blow by / crankcase pressurisation issues.
