stuarthellard Posted April 10, 2017 Report Posted April 10, 2017 Hiya all My fuel gauge does not work, after further investigation found it was not connected at the rear of the gauge, I cant find the leads to connect so I thought easy enough just find the lead from the tank and run a fresh wire. Problem is I have x2 wires coming from the top of the tank and both are black.... I would imagine one is the earth which I would need to earth to chassis and the other I would need to connect to the one terminal on the back of the gauge whilst a live is on the other terminal. Never had to rewire a fuel gauge before so a bit new for me. Any advice ? as I thought the sender unit normal earthed to chassis so I was surprised to see the x2 wire. cheers Stu
