hooligan Posted April 14, 2019 Report Posted April 14, 2019 Hi , does anyone know if a crossflow rear case gasket is ok to use on a pre crossflow ? I have fitted one to my engine and stupidly did not check it assuming I was given the correct gasket, I am using a Cometic gasket and they do not list one for pre crossflow and that was what I was sent. Thanks for reading
notenoughtime Posted April 20, 2019 Report Posted April 20, 2019 The only difference is the seal on the sump cork pre xflow or rubber xflow but I’m sure early xflow also use cork
