Just put my shell on a caroliner jig, I’ve got the chassis dimensions off the net but struggling a bit to put them into practice. Does anybody have a caroliner sheet for the mk2 escort it’s sheet 7:004 I know it’s a bit old like me but I’m still around....lol managed to get some discs but they can only be read in windows 95. I’ve sent them to a pc whizz but wanted to crack on. Hopefully someone may have the sheet and email a copy. Cheers 👍
5 minutes ago, eeb43 said:
what crossmembers and brackets have you got?
I can get the full kit, I’ve started using the rear spring front mounts as a datum point as I believe from the B post is out. With drop lines and approx measurements it is. But the sheet off the net doesn’t give enough details. It assumes the chassis rails are straight but I can’t find a datum line elsewhere or be able to arrive at one to check everything.
