mitomad Posted March 21, 2007 Report Posted March 21, 2007 what four pot brakes are there avaliable for osf's? Im guessing that most of them are interchangeable between the old fords? Just asking for a friend whos building a kit car based on a Mk3 cortina.
Gareth Posted March 21, 2007 Report Posted March 21, 2007 You can get: Princess 4 pots- budget. Or Hi spec upto the likes of Wilwood. Jus check out CF/RF mags for prices/stockists
mitomad Posted March 21, 2007 Author Report Posted March 21, 2007 The only problem is that he is using a stupid offset on the wheels so space is a bit tight behind the wheel. Does anyone happen to have a caliper lieing about who could measure the distance from midway in the disk clearence to the furthest point of the outer side of the caliper. Does it use vented disks? and if so do you know what size the disk is?
Methodz100 Posted March 21, 2007 Report Posted March 21, 2007 You can use the vented capri disk's along with the AP 4pots and a spacer kit which I would imagine is easy to find in UK. The AP calipers are heavy.
Mk 1 Mark Posted March 21, 2007 Report Posted March 21, 2007 i have vented 2.8 discs and willwood calipers on my mk1 cortina Rally sesign do a kit.. But i had capri calipers and it fitted nicely under my 13" wheels
