luz008 Posted March 30, 2007 Report Posted March 30, 2007 Starting putting my gearbox back together and realised i dont have the complete section from the haynes manual. need the torque setting for the 5th gear , main casing bolts aswell please Please help - need for tomorrow if possible oh yeah its for a type 9
Jimbob-Squarepants © Posted March 30, 2007 Report Posted March 30, 2007 These are the torque settings for the following on the 5 speeder in my Capri: Clutch Housing To Gearbox = 39 to 48 Nm Clutch Housing To Engine = 30 to 37 Nm Gearbox Case Cover = 17 to 21 Nm Gearbox Top Cover = 9 to 11 Nm 5th Gear Collar Nut = 120 to 150 Nm 5th Gear Locking Plate = 21 to 26 Nm Hope this helps
luz008 Posted March 30, 2007 Author Report Posted March 30, 2007 thanks mate is there a setting for the bolts which join the main casing to the tail section - cant remember the correct words.
Jimbob-Squarepants © Posted March 30, 2007 Report Posted March 30, 2007 I can only assume that it is the extension housing, so if that is the case, the torque settings for that are: 45 to 49 good old Newton Meters
