johnny_h Posted April 21, 2007 Report Posted April 21, 2007 Took the Mex for a blast to make sure she was ready for the pod and shortly after thrashing a BMW round the lanes I opened the bonnet to find fuel dripping. It stopped after a while and then I started the engine and ran it with no further drippage. Any ideas please?
Delotus Posted April 21, 2007 Report Posted April 21, 2007 Has your motor got a fuel pressure regulator? May need backing off a little,if itS over fueling it will fluId the carbs and drip as the needle valves wont be able to cope.. Mine was doing the same and the regulater needed backing off a little. Just an idea thats all for you to think about. Excellent camera work by the way Tim
V8ian Posted April 21, 2007 Report Posted April 21, 2007 Three possible causes, Float level, Fuel pressure, or Airbourne reversion, my guess is the latter, I cant remember the full reason but I think its to do with cam design, restrictive exhaust & exhaust primaries, where the exhaust is meant to deliver a pulse to cause extraction, and causes a pulse in the inlet and blows fuel out at certain revs-- I do fully expect to be corrected Ian
johnny_h Posted April 21, 2007 Author Report Posted April 21, 2007 Thanks, there's no regulator just the standard mechanical pump.
ever88 Posted April 21, 2007 Report Posted April 21, 2007 in that case an upgrade is required for defo. mechanicals in my experience work their backside off just to fill chambers. off course it's engine Dependant that controls jet size etc to fuel right but on a roller session I was going lean due to starvation.
Guest MK1gaz Posted April 22, 2007 Report Posted April 22, 2007 Twin dcoes only need 2 psi of fuel pressure and the standard mechanical fuel pump at idle will exceed this and petrol will leak out . Fit a fuel pressure reg and your sorted
stu Posted April 22, 2007 Report Posted April 22, 2007 ive got 1 on mine i just put it on the rolling road & hoped 4 the best. but i was told at box hill that it is a wise move2 fit a gauge as well so u can keep an i on presure. & play with it if need b.. dont know how much they r. the other lads could prop put u right from here
