Alan G Posted May 14, 2007 Report Posted May 14, 2007 Will this do the business instead of a bias box? I'll be running princess 4 pots up front and mk3 fiesta calipers & discs on the rear?? Comp brake do one for £34 http://cgi.ebay.co.uk/BRAKE-BIAS-PROPOR ... dZViewItem
v6pop Posted May 14, 2007 Report Posted May 14, 2007 Alan,the proportioning valve is normally used to adjust the amount of brake efficiency to the rear brakes.If say you have disc brakes on the rear and they lock up everytime you brake then you can restrict the fluid pressure by turning the knob to stop this happening.They fit this in a different form to vans and pickups to automatically adjust rear brake efficiency depending on what amount of load carried(works by a lever from the axle to the body mounted unit). I have modified one of these units easily to adjust by hand,got it from a scrap yard,think it was off an 80's fwd escort van! Hope this helps.
Alan G Posted May 14, 2007 Author Report Posted May 14, 2007 Thanks for the info pop! But I'm just wondering if I keep my standard pedal box and fit one of these proportioning valves in the brake line will it work and not sending me facing the wrong direction... basically will it be able to adjust the bias to the front so the rears won't lock up before the fronts! or... Should I just go buy a bias pedal box~
Rick Posted May 15, 2007 Report Posted May 15, 2007 you fit it in the line going to your rear brakes to reduce the braking force. i think you can dull it down by 60% with that particular valve. then you set it up til it feels right
petrolhead01 Posted May 15, 2007 Report Posted May 15, 2007 Thanks for the info pop!But I'm just wondering if I keep my standard pedal box and fit one of these proportioning valves in the brake line will it work and not sending me facing the wrong direction... basically will it be able to adjust the bias to the front so the rears won't lock up before the fronts! or... Should I just go buy a bias pedal box~ it will do just that!!! got one on mine for the same reason!!! and its fine!! if i adjust mine all the way in it actually cuts all pressure to the rear brakes which makes for wicked rolling burnouts with a little bit of brake just to hold her back but keeps the rubber smo king!!!
Alan G Posted May 15, 2007 Author Report Posted May 15, 2007 Thanks for the info pop!But I'm just wondering if I keep my standard pedal box and fit one of these proportioning valves in the brake line will it work and not sending me facing the wrong direction... basically will it be able to adjust the bias to the front so the rears won't lock up before the fronts! or... Should I just go buy a bias pedal box~ it will do just that!!! got one on mine for the same reason!!! and its fine!! if i adjust mine all the way in it actually cuts all pressure to the rear brakes which makes for wicked rolling burnouts with a little bit of brake just to hold her back but keeps the rubber smo king!!! Where did you buy that from? Compbrake? Wilwood?
petrolhead01 Posted May 17, 2007 Report Posted May 17, 2007 Thanks for the info pop!But I'm just wondering if I keep my standard pedal box and fit one of these proportioning valves in the brake line will it work and not sending me facing the wrong direction... basically will it be able to adjust the bias to the front so the rears won't lock up before the fronts! or... Should I just go buy a bias pedal box~ it will do just that!!! got one on mine for the same reason!!! and its fine!! if i adjust mine all the way in it actually cuts all pressure to the rear brakes which makes for wicked rolling burnouts with a little bit of brake just to hold her back but keeps the rubber smo king!!! Where did you buy that from? Compbrake? Wilwood? got mine from speedshack a long time ago!! i may have a brand new wilwood one somewere if you are interested!! i will have a look for it!!
Alan G Posted May 17, 2007 Author Report Posted May 17, 2007 Yeah give me a shout if you find it... I'll take it off your hands!!
quickrack Posted May 17, 2007 Report Posted May 17, 2007 Just be careful not to end up spinning the car when you fit the rear discs before you get the valve set. And make sure its working okay in the wet also. Good luck bud!
