Hey guys,
I'm looking for a definative guide on how to build up an LSD into the axle! I've had a read off a few guides and found that they were a bit too vague.... Could anybody lend me a hand and tell me EXACTLY what has to be done to get it done right for fast road spec!
If you have never built up a diff before dont try it yourself as you could damage your diff in afew miles if its not right :shock:
Its all done by feel and dti gauges m8. Fitting the LSD is easy but you need to set up the diff again after you have fitted it.
