Guest cortinamad-gonetoo
im not 100% sure but isnt second gear a different ratio :?
n type 5speed 3.65 1.97 1.37 1.00 0.82
4speeds
a1 3.66 2.18 1.43 1.00
a2 3.34 1.99 1.42 1.00
b 3.65 1.97 1.37 1.00
c 3.58 2.01 1.40 1.00
straight from the sierra haynes manual all for the sierra boxes :wink:
didnt either retroford mag cf mag do a write up on them a few months back
4speeds
according to that your right darren :thumbsup:
I thought the 2.8 i capri boxes were the better ones :?:mrgreen:
input shaft too long mate :wink:
My Dad machined Pip's input shaft for him, he is running a 2.8 box in his mark 2 escort to match his new engine :thumbsup::D
4speeds
Thank you :mrgreen:
Guest MK1gaz
There's a few different models of each gearbox type all with different ratios as well :? Standard Type 9 5 speed ratios are crap though :sad: , short first , long second etc etc and some 4 speeds are the same without the 5th . :thumbsup:
4speeds
You asked for the difference between the RS 4speed and the Sierra type 9.
Jason qouted 4 speed Sierra box ratio's.
4speeds
Have another look Ntype 5 speed, same as type e 4 speed, ie ratios are the same except one has 5 gears :thumbsup:
