Ok help needed in the thickie corner :mrgreen:
can any one explain wheel ET to me as its fooking with my noodle :shock:
my old 17" chav rims had a ET of +38 but when I messured the back spacing it messured 138mm
Now is 100mm a bace line and anything over that a + like mine +38 = 138mm :huh:
so if a rim has a -10 is it a 90mm back spacing
Now if Ive got that right (dout it tho :( )
what Et is a mk1 escort and is a mk2 the same
or have I got this compleatley tits up :roll:
The centre line of the wheel is 0.
+38 means that the mounting face is 38mm from the centreline, towards the 'outside' .
-10 means the mounting face is 10mm from the centre line,
towards the 'inside'.
I think thats right , but as always im happy to be corrected if the info that im dishing out is complete codswallop :thumbsup:
wheels have equal beads .. so you can measure from inside or outside ..you just need to find the centerline .
and then its the distance the the mounting hub face is away from the centerline that is the inst or offset .. oh and the et confuses me .. i thought ET phoned home ages ago
