Rick Posted August 16, 2007 Report Posted August 16, 2007 im after some hardened steel bolts to fit the doors as oppose to hinge pins. cant find what i want anywhere though. basically im after a hardened steel bolt with long shaft and small thread on the end, and obviously to fit the diameter of the hole, although slightly larger i could redrill the hinges any ideas ? anyone got some?
flyingbanana Posted August 16, 2007 Report Posted August 16, 2007 try here bud http://www.anglianfasteners.co.uk/
Rick Posted August 16, 2007 Author Report Posted August 16, 2007 cheers i dropped them a message to see if they can supply them
Rick Posted August 16, 2007 Author Report Posted August 16, 2007 allen head would be fine as long as theyre the right size and HT steel
escort new boy Posted August 16, 2007 Report Posted August 16, 2007 what length and what size do you want?
Rick Posted August 16, 2007 Author Report Posted August 16, 2007 il have to measure up tomorrow when im there and il post them here
Rick Posted August 16, 2007 Author Report Posted August 16, 2007 just measured a hinge pin to get measurements for you. il need 56mm of blank shaft followed by enough thread to get a nylon nut on diameter wise: 8mm should do the job hope you got somet
