jayson2.3pinto Posted September 21, 2007 Report Posted September 21, 2007 dragaddict hi m8 what total advance did you run in your 2.1 engine and what compression did you have
Ratters Posted September 21, 2007 Report Posted September 21, 2007 Mine don't like standard unleaded but I've found it seems to run better on Tesco's 'super' than it does on Shell Optimax/vpower for some reason. I use whichever one I'm near to at the time which is normally Tesco.
dragaddict Posted September 22, 2007 Report Posted September 22, 2007 dragaddict hi m8 what total advance did you run in your 2.1 engine and what compression did you have when i had my pinto total advance 33 deg. & compression 13.1 mate
Toby Posted September 22, 2007 Report Posted September 22, 2007 dragaddict. Hi there. What fuel were you running 13.1 with 33 degrees? I run V power with millers VSP but with much less compression and advance in my pre-crossflow. I don't think it would like much more as it has a tiny rattle as it comes on song. Would extra compression, timing and octane make much difference in your opinion / experience?
dragaddict Posted September 22, 2007 Report Posted September 22, 2007 the pinto that i had i gave her normal pump gas with 13.1 comp. & total advance 33deg & i gave her 150bhp of nos with 8 deg retard when switched on but still with pump gas. but i'm the to you guys it is a bit riski for the engine thow. but it ran fast for those days. about 7 years ago
