Help I've snapped the pins off my locking wheel nut tool!! How can I remove them? the centre of the nut is hollow & threaded - can I screw in a bolt with a couple of nuts locked on & undo it that way (like how you would retighten a loose stud?)
it works on those m8 mine were the same, for some reason had 3 different sets on the same car but only 2 keys!! lol use one of the sockets with lots of the little bits rather than the flat sided ones :thumbsup:
mate you're lucky. the metal on those is soft as shit smack a bi hexagonal socket on it, 18mm or an imperial one. make sure it goes on tight, put a knuckle bar on it and start putting pressure on it but at the same time keep hitting the back of the knuckle bar to keep the socket on tight and help with removal :wink:
very technical twink :lol:
couldnt think of the posh name!! i only know the posh names of human body parts :mrgreen:
hahaha :lol:
They come off a piece of piss mate, I find with them, if the first socket rounds it off it's usually cos they got a soft sh*tty casing around them, bang the next size down (usually changing to imperial/af/ww sometimes helps) and bang it on like your demented and it will come off no probs, then spend 1/2 hour trying to remove said bolt from socket in vice :lol::lol:
And if all that fails, the welded bar or big nut trick will never fail :thumbsup:
