Got one extra pipe left in the engine bay, looks like a fuel pipe...on the right hand side, and the tank and fuel line is on the left?
it had an essex in before hand, dunno if they have duel fuel intakes?
Just reading my original post and realised I never put across my reason for thinking that maybe a return.
On some Weber carbs, they had not just a fuel supply, but also a fuel return. Your question/problem is normally round the other way... "I have fitted my new carb, but it looks like it needs an extra pipe!" If you know what I mean :wink:
Do you know what engine you will be fitting??? If you find out what carb you will be using before you take the pipe out, the chances are, the new carb you may use may have the return on it, hence... a home for your pipe :wink:
its the 1300 in the pic that i will be using...far as i know thats got the standard carb on it.
may be upgrading to a 1700 xflow soon....
What shall i do with the pipe if its not needed?
leave the bung in it and cable tie it somewhere out the way high as possible
if your going 1700 you'll be wantin a 32/36 or a 38 i believe both have fuel return bittys on them
Got me thinking now and thats 2 early. :lol:
Its not fuel ... really its not .. its the servo pipe ..
The 3.0L V6 Essex engined estates all came with a remote servo , atlas axles with a 3.09:1 C.W.P , anti-tramps and 2.8i legs with the vented discs and M16 calipers
Honest ..they did :wink:
yeah the servo is up under the dash in the passenger footwell...
Its meant to connect to that! Hmmm i shall have to have a lookies!
Cheers....at least i know where it goes now!
