mk2 stu Posted November 17, 2007 Report Posted November 17, 2007 Right got some money together to take the build to almost the last stage, But need help. Where is best for propshaft? Was thinking propshaft services? Where can i get m12 rs wheel nuts ? Wheres best for brakelines and fittings! Oh and anyone got a spare £500 for all the carbon i want!!!
V8ian Posted November 17, 2007 Report Posted November 17, 2007 Best place for Wheel nuts is probably Speed Shack, http://www.speedshack.co.uk/ Hoses would be Think Auto, http://www.thinkauto.com/
Mk 1 Mark Posted November 17, 2007 Report Posted November 17, 2007 J W Engineering is where i get my Propshafts.... Same day if you supply the Ends (Diff And gearbox) in Kent Cheaper for cash aswell http://www.kellysearch.co.uk/gb-company-300001632.html And whilst in Kent Rally Design for brake lines
mk2 stu Posted November 17, 2007 Author Report Posted November 17, 2007 J W Engineering is where i get my Propshafts....Same day if you supply the Ends (Diff And gearbox) in Kent Cheaper for cash aswell http://www.kellysearch.co.uk/gb-company-300001632.html And whilst in Kent Rally Design for brake lines Cheers gents
James HPE Motorsport Posted November 17, 2007 Report Posted November 17, 2007 if you didnt already know stu there is a place in chessington called graystons who do every type of wheelnut for a ford including the collar type for revolution wheels and they do the studs aswell!! They also do bits like bonnet pins and the like!!! I would say think automotive in Ilford?! is the best place for service and quality, will sell you exactly what you require over the counter!!! Probably not the cheapest but certainly the best quality and there is no point in skimping on things like brakes now is there!!!!
Guest MK1gaz Posted November 17, 2007 Report Posted November 17, 2007 For all things fluid then www.thinkauto.co.uk is the place
Tom Posted November 17, 2007 Report Posted November 17, 2007 Where's Graystons mate? Stu, if you want brake pipe just ge it from somewhere like C.A.F mate a 5 metre rolll is about a tenner trade and the ends are about 20p each Actually, Tony Allen Motors will have it all
Mr.Sumo Posted November 17, 2007 Report Posted November 17, 2007 Where's Graystons mate? Chessington Ind Estate Tom Go into the Estate from the Toby Jug r"bout , follow road up til you go round a right hand bend , think its the 2nd/3rd? turn on the left past the bend...there at the top of the hill , last unit on the right , just before you hit the housing estate bit Hope that helps m8
James HPE Motorsport Posted November 17, 2007 Report Posted November 17, 2007 Where's Graystons mate? Chessington Ind Estate Tom Go into the Estate from the Toby Jug r"bout , follow road up til you go round a right hand bend , think its the 2nd/3rd? turn on the left past the bend...there at the top of the hill , last unit on the right , just before you hit the housing estate bit Hope that helps m8 Thats it, its the 2nd left and that is Roebuck road, the first place on the right is where I work and the turning for graystons is an alleyway on the right just before the first house at the top of the hill!!!
Gareth Posted November 18, 2007 Report Posted November 18, 2007 Want help spendin £500 You could give it to me and I'll spend it on a new block
