aden Posted December 28, 2007 Report Posted December 28, 2007 i know it aint ford but wondered if anyone could help me out! ive got a 98 sri vectra and its suddenly lost its oil pressure, any one got any ideas? aint had a chance to take the bag of shi*e apart yet, do not need this xmas week
V8ian Posted December 28, 2007 Report Posted December 28, 2007 Have a word with Russ, "RustyPup" on here, he knows about pressure loss on Xes
ratman Posted December 28, 2007 Report Posted December 28, 2007 I had a 97 vectra mine did the same its the oil pump it has got plastic gears they shear bet your bottom dolla thats what it is but its engine out jobby and the new pump was over £180.00 they are pure
aden Posted December 28, 2007 Author Report Posted December 28, 2007 I had a 97 vectra mine did the same its the oil pump it has got plastic gears they shear bet your bottom dolla thats what it is but its engine out jobby and the new pump was over £180.00 they are pure just spoke to a mate and he reckons the same thing, that the oil pumps shear, oh sh*t just what i need, really hope i can do it without taking the engine out
ratman Posted December 28, 2007 Report Posted December 28, 2007 just spoke to a mate and he reckons the same thing, that the oil pumps shear, oh sh*t just what i need, really hope i can do it without taking the engine out engine out jobbie cost me £600.00 to have it fixed and sold the car 1 month later for £1000 as I said
aden Posted December 28, 2007 Author Report Posted December 28, 2007 think im gonna lie down now and cry
Muttley MK2 Posted December 28, 2007 Report Posted December 28, 2007 You can replace your oil pump without taking the lump out, you will have to remove the cam belt and all ancilleries, also the sump, its a tedious job but can be done. The pump is not cheap and also you shoul replace the cam belt!
aden Posted December 28, 2007 Author Report Posted December 28, 2007 You can replace your oil pump without taking the lump out, you will have to remove the cam belt and all ancilleries, also the sump, its a tedious job but can be done. The pump is not cheap and also you shoul replace the cam belt! ive done the 8 valve ones before and i know they are the same as the xe, which aint too difficult, but someones told me that the ecotec crap ones are at the back of the engine?? sorry i know this aint an old skool ford question, but i could do with all the help i can get
Muttley MK2 Posted December 29, 2007 Report Posted December 29, 2007 No mate, the ecotec oil pump is on the front of the crank behind the cam belt. Drop the sump and take off the cambelt and pulleys
aden Posted December 30, 2007 Author Report Posted December 30, 2007 No mate, the ecotec oil pump is on the front of the crank behind the cam belt. Drop the sump and take off the cambelt and pulleys phew hopefully shouldnt be too much of a drama then thanks a lot
Mk 1 Mark Posted December 30, 2007 Report Posted December 30, 2007 Pm Big rod as he breaks Vauxhall`s...Might be able to supply and fit you an engine fairly cheap... He`s in croydon and very helpful and cheap goodluck with it
aden Posted December 31, 2007 Author Report Posted December 31, 2007 Pm Big rod as he breaks Vauxhall`s...Might be able to supply and fit you an engine fairly cheap...He`s in croydon and very helpful and cheap goodluck with it cheers mate ill bear that in mind, im gonna have a look 1st and see whats what though
