nice 1 wayne!!! :thumbsup:
As others said, rocker cover is a nice touch!!! Are you having them made or did you have the WPE machined into it?
that ones a tester but will get more done at some point. its machined into it :thumbsup:
Photobucket
Photobucket
one for the road. dry sumped short stroke x/flow on 45s :thumbsup:
2 things mate.
Why dry sump a road engine, and what's the capacity and how is it acheived if it's not a secret!! :thumbsup:
as for dry sump then why not? i had so might as well use it as the cars early hotrod replica whitch all used dry sump x/flows. capacity is 1650cc fulley lightend biscuit flywheel old skool powermax pistons 85mm. head spec ******** :lol:. cam is kc --- :thumbsup:
Why not indeed mate! That will be the t!ts :ykt:
Thanks for all the usefull info too!! :mrgreen:
Is the CR____ and the stroke____with a _____length rod. Does the flywheel weigh____reving to____with a ____gearbox?
:mrgreen::mrgreen:
Fair dinkums mate! :thumbsup::thumbsup::thumbsup: (I got it off neighbours) :lol:
:mrgreen::mrgreen:
if it does what its ment to do then it should be fairley quick but you never know we will see :wink:
