bmxdave Posted February 24, 2008 Report Posted February 24, 2008 I want to fit twin 45's or throttle bodies or bike carbs on my pop. But i dont reckon i have the space. Have any of you fitted such a setup on a pinto 100e before and do you have pictures? Have a look at my pictures below, and let me know if you think i could fit any in there without any cutting and chopping. On it now is a 38dgas.
mk1mexico Posted February 24, 2008 Report Posted February 24, 2008 You could only try mate, but looking at the pics i would say you will be struggling with twin webers. Bike carbs sometimes seem to 'bunch up' closer together so they might be a better bet.
V8ian Posted February 25, 2008 Report Posted February 25, 2008 Old skool geezer has bike carbs on his Pintoed 100e, and the 4 door yellow one with pinto has bike injection
Wessie Posted February 25, 2008 Report Posted February 25, 2008 im sure george got his set up from bogg brothers (correct me if im wrong) i suppose it all depends on the inlet manifold you use
DAZZA Posted February 25, 2008 Report Posted February 25, 2008 yes george was on bike carbs & Bogg Bros set up, seem to all go in OK
M.Bird412E Posted February 25, 2008 Report Posted February 25, 2008 Your gonna have to move that bulkhead over or at least back. That corner gonna catch the inlet manifold and if it doesn't it'l hit the carb! Its not a hard job to trim that corner out and replate it!
antz Posted February 25, 2008 Report Posted February 25, 2008 im sure george got his set up from bogg brothers (correct me if im wrong) i suppose it all depends on the inlet manifold you use i seem to think they can supply you with a full kit including the carbs themselves but i might be wrong. I know they do custom manifolds etc etc etc.
Guest MK1gaz Posted February 25, 2008 Report Posted February 25, 2008 No they won't fit unless you have an airsaw and a hammer
bmxdave Posted February 25, 2008 Author Report Posted February 25, 2008 Can you not get any offset manifolds? Or would that starve no4 cylinder? Id go downdraughts but i dont think i have the height availible.
