Baz. Posted March 1, 2008 Report Posted March 1, 2008 when i fit my rear discs, i dont want to use a bias pedal box, so can i use a brake proportioning valve to put more braking to the front? i dont want the car spinning around is anyone using one?? Bazzybaby
M.Bird412E Posted March 1, 2008 Report Posted March 1, 2008 Of course you can its only a pressure reducing valve.
M.Bird412E Posted March 1, 2008 Report Posted March 1, 2008 or you could get some mole grips and put it on the flexi that goes to your axle or hammer the brake line flat so it limits the flow of hydraulic fluid to the rear brakes............ Or not
Baz. Posted March 1, 2008 Author Report Posted March 1, 2008 or you could get some mole grips and put it on the flexi that goes to your axle or hammer the brake line flat so it limits the flow of hydraulic fluid to the rear brakes............ Or not errr thats not my style, and Tom thats wot i have been looking at adjustable, cool
M.Bird412E Posted March 1, 2008 Report Posted March 1, 2008 http://cgi.ebay.co.uk/Wilwood-brake-bia ... dZViewItem Like this! I knew what you ment Baz i was only messing
bomber1 Posted March 1, 2008 Report Posted March 1, 2008 or you could get some mole grips and put it on the flexi that goes to your axle or hammer the brake line flat so it limits the flow of hydraulic fluid to the rear brakes............ Or not dont we know u?
Baz. Posted March 1, 2008 Author Report Posted March 1, 2008 http://cgi.ebay.co.uk/Wilwood-brake-bias-valve-for-kitcar-race-car_W0QQitemZ140210683604QQihZ004QQcategoryZ23013QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Like this! I knew what you ment Baz i was only messing thats the kiddy
M.Bird412E Posted March 1, 2008 Report Posted March 1, 2008 get on american ebay and get one shipped over the exchange rates still good and their cheap there anyways!
Baz. Posted March 1, 2008 Author Report Posted March 1, 2008 Got one from rally design mate you not using a bias pedal box then??
Noodles Posted March 1, 2008 Report Posted March 1, 2008 Nope, i mean im no expert but the only advantage to a bias pedal box is each line has its on cyclinder and gives more pressure, dunno
M.Bird412E Posted March 1, 2008 Report Posted March 1, 2008 Nope, i mean im no expert but the only advantage to a bias pedal box is each line has its on cyclinder and gives more pressure, dunno A bias will displace more hydraulic fluid, also mean's you have two separate brake circuits and if you boil a fluid in one circuit the other circuit will still work. It's also proper handy if one master cylinder fails you still have the other that'l work to stop you.
Noodles Posted March 1, 2008 Report Posted March 1, 2008 Nope, i mean im no expert but the only advantage to a bias pedal box is each line has its on cyclinder and gives more pressure, dunno A bias will displace more hydraulic fluid, also mean's you have two separate brake circuits and if you boil a fluid in one circuit the other circuit will still work. It's also proper handy if one master cylinder fails you still have the other that'l work to stop you. Cool
duttnut Posted March 1, 2008 Report Posted March 1, 2008 I'm going to have a go at making one http://hometown.aol.com/dvandrews/bpvalve.htm
toad650 Posted March 2, 2008 Report Posted March 2, 2008 Would say that if you gonna be using it mainly for road stuff your better off getting an auto adjuster thingy, like the ones fitted to most cars as standard like the 2.8 cappa and most of the plastic escorts etc. These will adjust to the road type etc. The adjustable ones are more for track so that you can get the best braking for one track by dialing it in but even then it'll only be set up to work best in certain corners but then when camber changes etc you setup will be let down. Hope that makes sence, i got a bias valve off an escort i think, down the breakers for about a fiver.
