i have fitted a bolt in cage into my mk2 escort and now it seems to be in the way of refitting the standard seatbelts at the bottom of the B post.
has any one else had this trouble or know of an easy solution?
i thought about bolting to the cage but not sure if thats MOT legal.
gonna fit harnesses anyway as its a trackday car but wanted standard belts as well as its easier for the road.
Guest MK1gaz
you need the early type seat belts then they will fit :thumbsup:
Once you get used to the harnesses, you wont be bothered about the standard belts :thumbsup:
Plus.................think of all that additional weight of the standard belts :lol:
youve caged it you may aswelkl fit harnesses.
hard as fook to get on it your taller than 4' but 8)
Guest cortinamad-gonetoo
got to have harrness"s you soon get used to them for the road too :thumbsup:
i bought the cage second hand so not sure of its age. i think i will MOT it with harnesses and see if i get fed up with them on the road.
interesting about being able to fit the early type belts, are they smaller?
