Both blocks are the same My pinto has a cossy bottom and a titan dry sump twin scavenge type
Pace do a Cossy kit that has a 4th scavenge for the YB turbo but I recon a twin scavenge kit will be fine on YB Turbo and N/A
what about if its being used on track?
Guest MK1gaz
I've also got a Titian twin scavenge sump and pump on my Atmo Cossie engine which is the same as Ratmans pintos got . Pace Products do the best kits though , defo get their oil tank at least as these split in half to allow cleaning :thumbsup:
Guest MK1gaz
thought so, but im sure ive seen 2 seperate kits advertised. 1 for cossy and 1 for pinto.
Maybe the cossie kit is for a plastic s.ierra and not an escort etc :thumbsup:
If you are byeing new I would go for the Pace kit (much better quality) as Gaz said
Get the 4th scavenge type and you can blank that off until you go YB turbo
Guest MK1gaz
Gaz you got a tin sump on yours ??
Yes mate , twin scavange job :thumbsup:
That will be the next thing to fall off then :mrgreen: Mine had cracked twice :roll:
was going to bye a new one but burtons want £357.49 :shock:
Guest MK1gaz
It's already fell off nearly :mrgreen: . I spotted the bolts hanging off last week when i was checking everything :thumbsup: . Where has yours cracked then ? Mines quite old and has previously raced in the Ford saloon car championships for a number of years and not cracked :thumbsup:
On both sides of the rear crank seal and by the front sump plug :sad:
mine saw a lot of action from new going round & round the south england ovals in my starlet hot rod then sat on me garage floor for 8 years :mrgreen:
she still gently weeps cant be a old ford unless they leak ! 8)
Guest MK1gaz
Lol , mine leaks oil everywhere as well . Free rust proofing :thumbsup:
Guest MK1gaz
Using Gripfill would work i reckon , you would need a hammer + chisel to get the sump off then !!!!! :mrgreen:
