im just after a bit of advice please. iv got new rear bearings for my english axle and im just wondering what is the best way of getting the old ones off the half-shafts.
thanks in advance
tom :thumbsup:
grinder on the casing (be sure not to grind the securing bush)
then shatter with a hammer and chisel.
do the same for the inner part :thumbsup:
you can see the bush in the pic, that needs hammering back over when you got your bearing on again using a piece of scaffold pole if you got one. some people then tack it in place too
