Hi guys,
Going wiring up my electric facet fuel pump in the next few days... I've a few questions:
I've got a toggle switch (on/off) & when the pump is in switched on I've got a green light that I want to light up!
1) Whats the best way & how to do it?
2) What relay / fuse should I use?
3) Could anybody whip up a wiring diagram for me as Ratters knows I'm a tit with electrics!
Cheers lads,
:beer:
run a live from your ignition to your switch, from your switch to your light, from your light to your pump and earth your pump onto the body. put your fuse between your ignition switch and your pump switch. :thumbsup:
it depends how many amps the pumps gonna pull really, you can wire it as above but generally there wired in with a relay.
Get a 4 terminal relay, relays are basically a switch 2 termainals swithch the other 2 terminals.
To do this you'd run a low amp spur from the ignition with a fuse the switch and the green light to one terminal of the relay and earth the corosponding terminal, then when you turn your ignition on the relay with connect the other 2 terminals, when you flick the switch.
So the 3rd terminal run a high amp wire from battery with a fuse and the 4th to the pump pos terminal then just earth the neg terminal of the pump or the pump body if thats how it works.
Wiring it in this way although it sounds complicated will protect your ignition circuit and with stop interferance (ie noises through your radio etc)
Its not that easy to explain in words hope this helped but if you need help give me a shout or google wiring up a simple relay
Make sure your using a switch live that stays live when your cranking the engine as you won't be getting fuel to the engine when your trying to start, i did with with my ECU n wondered why the car wouldn't start :sad:
You could wire it in to a perminant live but then you'd have to remember to turn the pump off.
Good luck :mrgreen:
