am out in the rain trying to sort my clutch cable out keep vibrating loose there is only one nut on it so cant lock anything to it,any ideas lads and lasses,or has anyone else had this problem, :sad::sad::sad::sad:
u mean the nut an bolt that screws into the bellhousing?
pop the clutch off an put another nut on it (as a lock nut)
im sure it shud have 2.(mine does)
everything still good for the show at norfolk showground mate?
take it out and put another nut on there, then lock them together there should be 2 :thumbsup:
the thing being you cant get another nut on that fits the thread dew to the bulg that holds the cable in the clutch folk so am sure this cable only cam with one nut,even the genuine nut thats on it doesnt come of ???????shaun everything still gogo for the norfolk showground mate and you LEON if your still up for it lads, :thumbsup::thumbsup:
I have now filed the bulge down just enough to get another nut on,but now Ive had enough of getting soaked so will carry on tomorrow after work thanks for the ideas lads and will see you all next weekend :thumbsup::thumbsup::thumbsup:
You could cut a slot in a nut so it slips over the cable. You wouldn't be able to do it up super tight but a bit of thread lock or super glue would do it ;)
I was gonna suggest that but after i'd typed it i thought it was a bit of a 'tom' job and wouldnt work :lol::lol:
