garyv6100e Posted June 3, 2008 Report Posted June 3, 2008 Hi i have got a leak on my oil cooler sandwich plate to engine block joint . i did not build this engine so question is should the plate screw off the original oil filter connection . i dont want to damage it so any advise please
BIG G Posted June 3, 2008 Report Posted June 3, 2008 undo the large nut in the middle and the plate will come away
john_3.0s Posted June 3, 2008 Report Posted June 3, 2008 if its leaking between the block (or oil pump) and the sandwich plate then check the o ring is there (or not knackered)
garyv6100e Posted June 5, 2008 Author Report Posted June 5, 2008 Leak all sorted out now and treated the E to 4 litres of duckhams and a new filter . my oil pressure even increased by 15 psi very happy and ready for a weekend of OSF cruising
