This is SO frustrating, i cant begin to tell you all how annoying it is...
right, just rebuilt my engine (2.0 pinto in a capri) and as its been rebuilt the dipstick fell off (as it does) and its pissed oil everywhere.
i have sealed this up again, but have managed to run the car overfilled with oil for ~ 1000 miles (running it hard and propper)
now. i have a very strange oil leak.
When driving hard i have a spurt of oil which fires up onto the inside of the bonnet, between the inlet manifold of the rear 2 cylinders. and leaves a nice steamy mess on the inside of my bonnet!
the leak is not coming from the rocker cover, as the underside of both carbs (twin 45's) are covered with oil.
it is not the dipstick as i have cleaned everything up to try find the leak, and once the oil came back again, this area was still dry.
what else could be leaking (underneath the inlet manifold at the rear of the engine as i cant find the leak for love nor money, and its costing me loads in oil as it ends up on peoples driveways/the middle of the road and everywhere!!!!!
could be block breather... But sounds deffo pressure switch connector :thumbsup:
mine did this too, opened the breather up and run a breather cap and no problems...
Oh, and never ever overfill an engine with oil, i run mine halfway in between the 2 marks on the stick.
cleaned out the oil breather on the rocker cover and thats all fine and clear now. still a leak.
whereabouts is the pressure switch connector and the block breather??
what they look like etc and how do i know where they are leaking from if they are leaking
and how do i fix them if they are leaking???
didnt know the block had a breather :):)
When mine did it it was the hose that runs to the oil pressure gauge - a tiny pin prick that shot oil all over the bulkhead, only when the engine was running of course.
That's waht my money's on.
The block breather is under the inlet manifold, that box thing right in the middle, can't miss it :? should have a pipe out of it running to the inlet manifold, i say should cos if it aint on there that's prolly where the oil mist is coming from.
but TBH you usually get fumes not actual oil at pressure so personly i'd take the oil pressure switch out and plumbers tape the threads.
Oh and too mutch oil is worse than too little in a pinto mine happyly runs off the dip stick but over fill em and you do all sorts of damage and blow seals ect :sad:
oh.... i guess i missed that when i put the new inlet manifold on.
is it the big circular rubber thing in the middle of the engine block on that side which the old manifold used to rest onto?
ill check the oil pressure tubing for pricks. although the guage on the dashboard still reads fine so i doubt its that, ill check anyway
thanks for the advice. ill get back to you once ive had a tinker this aft!!
