richie_stix Posted July 25, 2008 Report Posted July 25, 2008 been lookin on ebay at electric cooling fans of road cars to replace my belt driven one on the pinto, as a kenlowe or pacet are a bit steep for me at the moment... but they all seem to have a bit on the end of a wire that plugs into an ecu? how does one get round this? i would rather thermostaticly controlled but a dash swith wouldn't be the end of the world! also, any ideas how i might mount one to a radiator as they won't have a fitting kit supplied! cheers rich
bortaf Posted July 25, 2008 Report Posted July 25, 2008 Not sure about ECUs but they do all use a stat Burtons do a stat switch you put in the top hose, takes most standard ford fan switches so you can choose the temp you want it to come on at
5hane Posted July 25, 2008 Report Posted July 25, 2008 couldnt you trace the wires to positive and negative, wire em up and a switch on ur dash cant be that hard really
Gibson Posted July 25, 2008 Report Posted July 25, 2008 Nope. Demon Tweeks do a piece of pipe the same diameter as your top hose with a temperature controlled switch in it. (adjustable too) all you do is cut the top hose and put the piece of pipe in like you would attach it to the top of the rad (slip over nice and tight and jubille clip) its a hundred times more leak proof than the probes you can glue into the coolant pipes. and it looks nice too. Wire that into a Cavalier diesel rad from ebay (about £20 reconditioned) and Bobs your mothers brother!
petrolhead Posted July 25, 2008 Report Posted July 25, 2008 I'm not a pinto expert but sure some of the later pintos will have a thermostat switch. For my crossflow I got a thermostat switch from a Mk3 Fiesta and went around the scrappy with a tape measure. I got a Mitsubishi Galant fan for £15. When it kicks in it sucks in small children and the water temp drops by 25'c. Not bad for £20 all in
over_head_cam Posted July 25, 2008 Report Posted July 25, 2008 I'm not a pinto expert but sure some of the later pintos will have a thermostat switch. For my crossflow I got a thermostat switch from a Mk3 Fiesta and went around the scrappy with a tape measure. I got a Mitsubishi Galant fan for £15. When it kicks in it sucks in small children and the water temp drops by 25'c. Not bad for £20 all in That's the way to do it When we did Darrens, a fan of indeterminate Japanese origin was donated
richie_stix Posted July 27, 2008 Author Report Posted July 27, 2008 cheers guys, just the type of information i needed! don't really want a dash mounted switch in case i forgot to turn it on or something!
