Haynesmanual Posted August 9, 2008 Report Posted August 9, 2008 I knew my mk2s axle was not central but now i have the 7in revs on it its miles out! its almost touching on the o/s but the n/s has like an inch! is this normal? seems a bit extreme.
over_head_cam Posted August 9, 2008 Report Posted August 9, 2008 Have you tried the 'jack it up, undo everything, let it down then put it where you want it and do everything back up' technique?
countrybumpkin Posted August 9, 2008 Report Posted August 9, 2008 you could always put a panhard rod on the car and pull the axle to the center i had to do that on my mk1
