sambo Posted August 16, 2008 Report Posted August 16, 2008 Hi all, i jacked my car up today and turned one rear wheel expecting the other side to turn in the same direction but it didnt. I bought the car having been told it was running a 4.6 ZF motorsport LSD in the atlas axle etc. This business of the other wheel not turning got me worried and i quickly took the rear cover off to have a butchers. This is what i found....... What does this look like to you? I also, (before taking the cover off) spun the prop round counting the amount of turns to one turn of the wheel and it was 3.5 ??? Then with the cover off, i counted the teeth on the CW & P giving me 8 and 37. 37/ 8 = 4.625 ?? whats going on here then? The diff is clearly stamped 4.6 too? So, why wasnt the other road wheel turning with the one i was turning?? any help would be appreciated!!
X FLOW EDDY Posted August 16, 2008 Report Posted August 16, 2008 Well thats deffo an LSD there mate. The plates might be worn out or it might have lost all the spring preload.
V8ian Posted August 17, 2008 Report Posted August 17, 2008 I worried about my LSD when I jacked my car up, I could turn 1 wheel, and the other stayed still, Bet you reversed the car before you jacked it uo, this unloads the lsd allowing one wheel to be free, take it out for a drive and give it a bootfull, enough to leave rubber, I will bet you will have 2 stripes
sambo Posted August 18, 2008 Author Report Posted August 18, 2008 Cheers Ian, that is a weight off my mind. When i get a new gasket ond oil i will have to try that !! It makes perfect sense too.
