Retro-gone. Posted August 30, 2008 Report Posted August 30, 2008 the big oil seal that fits at end of the crank just does not wanna stay put, when i tighten the main bearing cap onto the seal it pops out, it says in manual to smear silicons sealer round outside edge of the seal b4 fitting it, i think thi9s is whats causing it to dislodge as it makes it slippy. anyone had same problem?
SmokeEm Posted August 30, 2008 Report Posted August 30, 2008 not had that problem mate but you might want to try setting your camera to the 'macro' position for close ups. (Little flower symbol) It takes a little longer to focus but perfect close ups are a button away
Retro-gone. Posted August 30, 2008 Author Report Posted August 30, 2008 f*ck the camera, this is a tad more important ! besides it doesnt have a little flower symbol , its an old digi camera, one of the 1st, very basic im afraid.
Rick Posted August 30, 2008 Report Posted August 30, 2008 put it in with locktite mate and give it chance to set
Retro-gone. Posted August 30, 2008 Author Report Posted August 30, 2008 ive put it in dry and seems ok, problem is now im gonna be worried its gonna pop out when the engines in and running ive never come across this problem when fitting oil seals. rick, im now fitting the piston/rods in the bores, any idea which way round the caps fit onto the rods? the rods and caps are numbered so do i put the numbers to the same side?
Rick Posted August 30, 2008 Report Posted August 30, 2008 think they only go on onw way mate, and there shud be an arrow cast in them pointing to the front. i put my seals in dry too mate and no worries
Retro-gone. Posted August 30, 2008 Author Report Posted August 30, 2008 the main end caps only go one way with an arrow but the big end/rod end caps dont, il just put them so the numbers are facing each other 1-1 & 2-2 etc, the numbers are on the rod and rod end cap. theres also a + stamped on the rod end caps but noidea what thats for.
Rick Posted August 30, 2008 Report Posted August 30, 2008 yeah the numbers etched are facing the same way, ideally you should keep it all ordered when you take it apart sounds like your having fun getting your hands dirty
Retro-gone. Posted August 30, 2008 Author Report Posted August 30, 2008 i know mate, i numbered, orded and and photographed everything.... except these
countrybumpkin Posted August 30, 2008 Report Posted August 30, 2008 yeah put the number on the same side as they would have been stamped when bolted together. as for the crank seal put it in dry but first bolt down the bearing cap not to tight then push the seal in and fully tighten the bearing cap once the seal is in properly it wont come out when its running i had this problem with my pinto i think repo sels are slightly bigger
