atm i have to always disconnect my battery as it appears to be drainging itself. its only since ive put the new motor in and ive treid two batteries? any suggestions?
also how easy is it to rebuild starter motrs its just mine is sticking all the time so it may need rebuilding?
the reason i say the starter motors dying is that it just turns over real slow and then randomly it will turn over quickly then slow...
but most the time when its warm you dont even hear it turn over before the car starts.
would a sticky solenoid cuase this and can i pull one apart and rebiuld it myself?
its for a 1600 cross flow, the only lead that wasnt connected is a green one coming out the side of teh loom just behind the alternator and appears to go into the block. my guess was this could be temp. guage?
whilst on temp. my guage doesnt go up, also neither of the pipes of the rad are cool? is there something wrong with that?
Green wire has something to do with oil pressure -
Your water temp is over on the opposite side - red and yellow wire!
To test your gauge - put a piece of wire into the bullet connection and touch to earth - your gauge should move all the way to hot!
If none of your pipes are cold, it could be the thermostat not opening... take the thermostat out, place it in a pot of water and start to boil it - you should see the stat opening... that means your stat isn't faulty!
