CapperTom Posted October 3, 2008 Report Posted October 3, 2008 Im after moving the water expansion tank for the rad off the rear firewall because i cant fit this with the tein carbs and filters 2, but was wondering does the tank have too be above a certain level because i was going too put it in the big space between rad and front of car? thanks Tom
countrybumpkin Posted October 4, 2008 Report Posted October 4, 2008 yes it dose have to be a at a certain hight if i remember righty low marks on the tank should be at about the same hight as the middle of the top tank of the rad if thats makes sence it has to be about this hight so the water can feed in to the rad and keep the coolent level correct
Messenjah Posted October 4, 2008 Report Posted October 4, 2008 or just get rid of it and have a stella can cable tied to the side of the rad with the overflow pipe into it and check the level every now and then ?
caprinerd Posted October 4, 2008 Report Posted October 4, 2008 ive moved mine to the osf next to the washer bottle had to move washer bottle forward 1/2 to 1 inch and expention bottle goes in there ok have also to shorten over flow pipe and thats all i did
crapichris Posted October 4, 2008 Report Posted October 4, 2008 swapped my washer bottle and overflow bottle around. The radiator overflow is now next to the radiator - so short pipe. The washer bottle is on the bulkhead of the engine compartment so stays warmer and doesn't freeze up so easily in winter
