frenchy Posted October 5, 2008 Report Posted October 5, 2008 now ive been ripped of bye nettles i need to do a shoping list for the 100e but i dont no where to start and what ones to get struts brakes / servo x member axle prop wheals rack / colum engine any advice would be good thanks
5hane Posted October 5, 2008 Report Posted October 5, 2008 well whats the engine goingto be? what is it going to be ? (ie fast road, concourse, track car..?) how much do u want to spend?
garyv6100e Posted October 5, 2008 Report Posted October 5, 2008 old ford auto's sell everthing you need for the front end (not cheap though) and you have to supply all the donor parts Rear axle is a 105E axle length is fine but you will have to repostion the leaf spring and shock mounts prop will have to be custom made my car has capri front struts coil over conversion (with ford classic top mounts) capri Xmember rack column anti roll bar and tca's and poly bushed only down side with this set up is the front wheels (6" with 155/65's) only just fit under the arches but all the parts are easily availble and cheap Engine is up to you but almost every engine you may want to put in will involve cutting the bulkhead and gaerbox tunnel good luck looks mint on the outside
5hane Posted October 5, 2008 Report Posted October 5, 2008 p105 speed do custom props, think there £105
Nettles Posted October 5, 2008 Report Posted October 5, 2008 Don't bother fella, give up now! Tell ya what I'll do ya a favour and take it off ya hands for £50 no more ok?
Jimbob-Squarepants © Posted October 5, 2008 Report Posted October 5, 2008 Oi Baron... keep it real mate, keep it Sidevalve Nettles... FROFL
