DanV Posted October 20, 2008 Report Posted October 20, 2008 After some careful consideration towards the use of my 100E i decided to use a xflow rather than a pinto for power due to the weight of the pinto. However, seems like 1600 xflows are thin on the ground and command a high premium for a good one. Does anyone know the weights of a 1600 xflow, 2ltr pinto and 2ltr Zetec?
ZetecVan 2.0 Posted October 20, 2008 Report Posted October 20, 2008 The Zetec 2.0 is 118kg. A pinto is around 650kg
DanV Posted October 20, 2008 Author Report Posted October 20, 2008 Christ thats heavy Im considering a zetec but i dont want it too front end heavy, i do a lot more B road driving than anythin else, so handling is more important than power. If the zetec is a better option to the pinto ill go for that instead. What dya reckon?
Noodles Posted October 20, 2008 Report Posted October 20, 2008 The Zetec 2.0 is 118kg. A pinto is around 650kg Yer its all dose plastic bits
Copey Posted October 20, 2008 Report Posted October 20, 2008 a pinto isnt that much heavier than a crossflow in all honesty but the zetec would be a better option, can pick em up for £50-100
vibrating_Cake Posted October 20, 2008 Report Posted October 20, 2008 The Zetec 2.0 is 118kg. A pinto is around 650kg hahahahahahahahaha
Mick The Mig Posted October 21, 2008 Report Posted October 21, 2008 I can't believe a pinto weighs 650kg. we recently weighed a rover 3.5 and gearbox at 227kg prior to fitting it into noodles project. Our best guess for the pinto engine alone is 120kg. We were going to weigh one, but noodles keeps taking them apart before we get a chance. Just wish he'd put one back together occasionally.
vibrating_Cake Posted October 21, 2008 Report Posted October 21, 2008 I can't believe a pinto weighs 650kg. we recently weighed a rover 3.5 and gearbox at 227kg prior to fitting it into noodles project. Our best guess for the pinto engine alone is 120kg. We were going to weigh one, but noodles keeps taking them apart before we get a chance. Just wish he'd put one back together occasionally. Physical dimensions Exacty how big is the Zetec engine? Well, you'd probably be surprised that it's not a great deal bigger than the X-flow. It is slightly taller, and longer, but not that much bigger. Length: From the edge of the water pulley, to the edge of the cylinder head, the overall length is 500mm Height: From the bottom of the sump, to the top of the oil filler cap, the overall height is 600mm Width: From the edge of the oil pump filter mounting, to the front edge of the block, the width is 340mm Weight: 115Kgs (the Ford Pinto weighs approx 133Kg)
DanV Posted October 21, 2008 Author Report Posted October 21, 2008 I can't believe a pinto weighs 650kg. we recently weighed a rover 3.5 and gearbox at 227kg prior to fitting it into noodles project. Our best guess for the pinto engine alone is 120kg. We were going to weigh one, but noodles keeps taking them apart before we get a chance. Just wish he'd put one back together occasionally. Physical dimensions Exacty how big is the Zetec engine? Well, you'd probably be surprised that it's not a great deal bigger than the X-flow. It is slightly taller, and longer, but not that much bigger. Length: From the edge of the water pulley, to the edge of the cylinder head, the overall length is 500mm Height: From the bottom of the sump, to the top of the oil filler cap, the overall height is 600mm Width: From the edge of the oil pump filter mounting, to the front edge of the block, the width is 340mm Weight: 115Kgs (the Ford Pinto weighs approx 133Kg) Perfect answer my friend To the scrappy!
