ive got an oil leak from the camcover, apparently a common problem on pinto engines if not done properly??
mine is the wide rocker cover and the wide gasket is fitted, the only leak is at the back where it cant be seen, so should i blather it in silicone sealer? ive got a new gasket too.
check the gasket didnt move when you put the cover on the engine, sometimes when you tighten them down they have a tendancy to try and move :?
i've always fitted came cover gaskets with gasket goo on the cover then grease to the head, tighten them all down then run the engine then retightonce its cooled and not really had any leaks, as with all cork gasket tho they need to absorb some oil so they expand and compleatly seal
