http://www.rallydesign.co.uk/product_info.php?cPath=562_579&products_id=13600&osCsid=b930atc0mefkc8mojithenr6u0
my drums just arent good enough.... are these the right brackets to convert to disks on the rear of a 2.0 capri laser???
i cant remember for the life in me what the diff name is!!!!
if these are not the right brackets...
what are (other than caprisport ones)
and ill have no paddying about me not needing rear disks etc, when you drive hard enough to get the rear drums smoking and setting on fire before the fronts even fade.... they need upgrading!
Wouldnt that suggest that they are doing too much compared with the fronts? maybe the balance just needs adjusting towards the front?
(Im asking rather than telling :wink: )
No, you have an Atlas axle & you will want calipers with a handbrake too, i use the common set up of seirra or scorpio callipers, fiesta front discs,i made my brackets but they are like the caprisport ones dont know who else sells them ???
The brackets will fit both english and atlas axles as the stud pattern is the same, i used same brake set up as hellblue but bought a bolt on bracket set from old ford auto services, was excellent quality came with colour photos and all new bolts and nuts and fitted perfect with no messing, highly recommend it just for the no fuss factor, just one more thing to check is that the set up your using clears your wheels as not all do
lol, its fine is the balance, full lockup in the dry will lock the fronts before the rears (thinking of which i havent locked the rears up at all really since the front brakes)
thing is with the balance, its 283mm vented disks up front with 9" drums on the rear.... the two things are in different legues!!!
also wheel clearance.... plenty! (16's)
you got a link to old ford auto's for the brackets???
interested in that one
Furry muff :thumbsup:
try clicking on the limk on the site :thumbsup:
www.oldfordautos.co.uk
click on MK1 MK2 escort :thumbsup:
e-mailed them and they said their rear brake brackets will not fit!?!?!?
this is because the capper has a different axel to the mk1/2 escort!
:(:(:( back to square1!!!
not up for paying £15 for membership for caprisport JUST to get rear mounting brackets for rear calipers!!
anyone???????
When i got my kit from them the pics showed brackets in photos and gave to different positions for english atlas, or you can buy the weld on brackets and use s ierra calipers, to be honest i cant see why they wont fit as ive used atlas drums brakes from a 2.8 on my english with no problems at all, so the bolt spacings are identical
ahh i cant weldddd =o(.
are you 100% on this????
as i need to know before buying stuff cause im running around with no rear brakes atm (highly illegal) but i just need the parts to come
and yes, opting in for the s ierra calipers.
