spa special Posted September 14, 2006 Report Posted September 14, 2006 im running a 2.8i capri with a turbo technics kit fitted. up until recently the car was running fine. but now im having problems starting the car when it is hot, but the main problem is the engine is pressurising the sump and is blowing oil/smoke out of the dip stitk and fillercap. please help im desperate!!!!!!!!!!!
caprifan Posted September 14, 2006 Report Posted September 14, 2006 ...take all the TT stuff off and give it to me, you know it makes sense... ....honestly, not sure on that one mate.....have you asked on the laser page as there are a few TT boys on there ?
spa special Posted September 14, 2006 Author Report Posted September 14, 2006 hi m8. the way it is going you are welcome to it. did try to go on the laser page but forgot my password
caprifan Posted September 14, 2006 Report Posted September 14, 2006 do you want me to post for you mate ?
caprifan Posted September 14, 2006 Report Posted September 14, 2006 ...done mate....I will post back here with any replies...
spa special Posted September 14, 2006 Author Report Posted September 14, 2006 thanks mate. i think fiesta steve may be right. coz it was fine one day and crap the next
caprifan Posted September 15, 2006 Report Posted September 15, 2006 replies so far mate : common problem on these im afraid.......loads are like it (inc mine)....peeps get round it by installing a catch tank.....possible causes to check first are ...... breather valve installed wrong.... piston has a tiny hole in it.... rings are fooked.... So obviously you do compression check 1st.... -------------------------------------------------------------------------- not had this problem with mine, but as TCK says, the breather system needs to be checked, and compression and cylinder leakage tests done. I have seen TT Capris running perfectly happy even without the breather system fitted, so make of that what you will.. the TT will always show up engine wear more than a standard engine due to the nature of the beast.
spa special Posted September 15, 2006 Author Report Posted September 15, 2006 thanks for your help m8. looks like i need a new engine
caprifan Posted September 16, 2006 Report Posted September 16, 2006 ...no worries mate...do a compression check first it may be ok....
spa special Posted September 16, 2006 Author Report Posted September 16, 2006 o.k did the compression test and the psi was about 120-130 i have been told it should be around 150-160. i can under stand one piston being low but not all six. i did the valve clearnces about 3 weeks ago so im thinking they should be right ( famous last words ) if anybody can me with this one i would be very greatfull and i will buy you a cup of tea at the next boxhill meet.
caprifan Posted September 18, 2006 Report Posted September 18, 2006 ...ok mate some more replies for you after I posted about the comp test.... next check its not pressurising through the drivers side rocker cover..fit a small free flow filter into this and block the breather pipe off that you remove (simply kink the hose and wire it). What boost pressure is it running?
